No Repliescan anyone help
kambon
"Rather than strip the parts d
"Rather than strip the parts down and take them to a dealer how do I find the part numbers for my engine so I can order them online.Here's hoping someone can help, need fuel pump and carb kit for my 1992 Magnum 40hp 4cyl 2stroke serial number 9753941, unsure as to number for kits etc. On the side of the fuel pump is the number 98766-01 and on side of carbs is 14494 is this the reference i need to replace the parts,also 2 stroke oil pump is looking a little the worse for wear,what is the part number for this."
"Hi Noel, thanks for replying
"Hi Noel, thanks for replying but I still need to know how to check for the part numbers, unless your advising to join another forum site and ask there.
Alan"
"Hi Alan, No I wasn't sayi
"Hi Alan, No I wasn't saying join another site,these are places to get the parts you need from the States.
In the UK you could always shout on www.billhinghaqm.co.uk ,he good with used parts. I find if I need new parts it is usually cheaper to get them in the States."
"Alan, if you are just looking
"Alan, if you are just looking to look up parts numbers you can go to www.mercruiserparts.com and follow the link "search with pictures" - find your model/serial and you will have everything you want to know..."
"Hi Graham, thanks for replyin
"Hi Graham, thanks for replying but all i'm after is how do I find the part number from the parts on the engine itself, specifically carb and fuel pump.
Alan"
