Hi there,
i have a 1983 crusader 270 with approx 2600 hrs in a Tolly 26 that has been running like a champ. We just came back from a weeklong trip. I had noticed on startup the last couple days a bit of a whine that sounded like a pulley but went away quickly when started. Last weekend I changed the oil and filter. She started right up and ran fine as I warmed up before the oil change. After I changed the oil and filter I restarted. My alarm buzzer sounded and stayed on and I noticed my oil pressure gauge at zero and shut it down. I read a bit online and see that in some cases the oil pump loses its prime and to fill the oil filter when replacing it. I have never done this but gave it a try. Same result. Are these symptoms of an oil pump failing? Just seems odd that it’s at same time as oil change. I have been using 10w-30. Have dual helms and oil pressure same on both. Thx.
