I just saw an article talking about the new SHOT system from BRP on their Ski-Doo snow machines. Check it out here: https://www.ski-doo.com/technologies/e-tec-shot-starter.html
Basically in the SHOT system they are using the magnets in the flywheel to and the coils on the stator to spin the crank. Then with a properly timed squirt of fuel and spark the engine kicks over and starts.
The Etec system in these skis is pretty similar to the Evinrude Etec outboards. I wonder if they'll move this system over to the Evinrude Etec outboards and eliminate starters? I'm sure the larger displacement of V6 engines would be a challenge but maybe in smaller 2 and 3 cylinder engines this could work just as easy as it does in the snow machines?
What's funny is a mechanic I knew before he passed away several years ago mentioned something like this when the FICHT engines first came out. He always talked about using the CPS to know which cylinders were at or just past TDC then give them a squirt of fuel and a spark to start the pistons moving. BRP says the crank only needs 1/3 rotation for it to fire a cylinder. If the magnets can move the crank on an outboard engine enough this could be a real possibility. It's not going to be a big weight savings for a 450lbs outboard but it would make a little room room under the motor hood.
I'm very curious to see if this will show up in the next round of Evinrude Etec engines.
KJ
KJ
