"When you push the control, th
"When you push the control, the gear shift push rod at the engine end does not move. The shift was very stiff prior.
i cant get the single lever control apart to investigate, although i have removed the 4 visible screws . It is a side mounted concealed cable type an a Seaswirl Striper. Any words of wisdom?
There are no parts here in Antigua so i will need to specify any parts right first time and import them. Thanks in advance for any tips"
