2003 Merc 50 ELPTO on 20ft pontoon. Rebuilt leaking fuel pump last week motor ran great using new 3 gal tank with fresh fuel and stabilizer. Old 24 gal tank in bad shape replaced it with a new 12 gal along with new line, fittings, and primer bulb. Same for small 3 gal tank that will be used as back up now. Now for the problem, no fuel will flow from either tank to engine no matter how many times you squeeze bulb. Checked to make sure pick up tubes were in place, heard air leaking from sprayless connector got brass barb fitting to stop that. Does any one have any ideas?
