redsnapper386
guy's,well i thought i was good to go after my last post on coil blow out.my motor ran good on the hose for about 15 min,then it shut down.i checked the coil & had fire,next i checked a few spark plugs grounded to the block,and this showed no fire.so this dist kit is on the way back to the seller for replacement.a new dist should not do this.if it tests out good then what could cause this problem. has any one had this happen,and what was the fix.i have double checked,and checked all wires,and connections,fuses,ect.all is as should be.all other componets on boat work well.i guess the sensor inside of dist could have gone out.once again thanks in advance.
