M
mike grubb
Guest
" I have a 1984 90 hp evinrude
" I have a 1984 90 hp evinrude. The down trim does not work, just clicks at the junction box. The box got water in it while fishing this weekend. Up trim just fine. There are two black square solenoids? in the box. Is there a way I can check the solenoids to determine if one or both are them are bad?
The other problem is the motor will run at 10,000 rpm, but die on acceleration. If I hit the choke button while in gear, it runs like it should. What is up with that? "
