jaschrumpf
Every time I look at something for the first time on this 1964 AQ100 I find something at which to marvel. This time I was looking at the prop with a mind to remove it and look at the shear pin. The first thing I see when looking at the cone one unscrews to remove the is that there is no place for a cotter pin. There's a hole through the tip of the cone, perpendicular to the axis of the shaft, just where one would expect to see a cotter pin hole -- only the hole does not go through the shaft, and it's way too big for a cotter pin; about 1/4" - 5/16" in diameter.
Then I notice that the rim of the cone is not smooth, but is crenellated, like the top of a rook in chess, or a battlement on a tower. I further observed that there is a metal ring on the propeller side, like a fender washer, that is also crenellated, and in the opposite pattern, so that the "teeth" of one side fits into the gaps of the other side. As the cone is screwed down onto the shaft it makes contact with the "teeth" of the ring, which click into place in the gaps until the cone is firmly screwed dpwn.
Sadly I did not get a picture today, but I will take and post one tomorrow. Right now I'm just curious to hear if anyone else has ever run across such a system for securing the prop onto the shaft, a ratchet/pawl-like combination in place of a cotter pin.
