Hi all my name is Mike and I have a 81 lund guide special with a 35hp johnson. I've had the boat since 1996, grandpa left to to me. The motor has ran like a watch up until last fall. I was trolling and it started puttering. I'm not getting combustion on bottom cylinder. Opened it up had water in bottom cylinder so checked head warpage and replace head gasket. Replaced thermostat as well. Compression was mid 120s before I did gasket and after new gasket. New plugs, tested plug wires, coils, power pack, sensor coil and charge coil as are spot on. Carb has been taken off cleaned and new needle valve. Gas in line and carb look fine. But motor still runs same. It putters at idle and bogs if I give I throttle like it's only running on one cylinder. My next and only thing I can think of is fuel pump. I read somewhere that a bad fuel could possibly flood bottom cylinder. Top plug looks perfect but bottom plug looks fouled and wet. Any other ideas would be tremendously appreciated. Thanks, this forum is a great resource and always better to have extra eyes, ears, and minds to help people figure out problems. Thanks again.
