benjammin8
Hi,
I'm a Newbie to thiis forum and I hope you can help. My 2002 6hp Nissan had not run for a couple of years. After the 1st use this year, I noticed gear oil coming from the small drain holes above the lower unit. After changing the gear oil (did not seem 'milky') I also noticed a leak from around the propeller. Does this indicate a LU seal problem? Is there a seal kit for the entire LU or do I need to diagnose and replace each leaking part?
