switchcaster
I just bought a 1985 NSF5B. Seems to start up fine. I just need to work on the carb needles.
I do have a question thought. I hope I can explain this without pics, if not I will have to post some. When I placed the motor in the test tank it seems to discharge a brownish lube/oil, not sure if this was gear oil or not. I checked for cracks in the lower unit and could not find any. Seems this oil is coming from to small ports in the front of the shaft. The ports are just above the hex bolt on the lower unit.
After I took it out of the water I wiped away the oil, it seems to be seeping out of these ports, it did end up stopping and seems not to be leaking anymore. Is there a gasket I need to replace? The exploded view of the lower unit does not show one.
Looks like a clean and well kept motor/low hours, and I assume it sat for awhile. Hope I didn't bite the big one on this. I spent $400.00, which I though was reasonable.
Please help thanks. Any other suggestions are appreciated. I was thinking of swapping out the steel tank for a plastic one, any thoughts?
