My NS5B longshaft with internal has quit running. Fully disassembled and cleaned carb including jet removal etc. I am very diligent about running the engine dry over the last few years since I have owned the outboard. Now, the motor will fire up with no problem and run for about 30 seconds and then just die. Since I reinstalled the carb, the motor will only start and run for a few seconds when I spray starter fluid into the air intake. The interesting thing is I loosened the float bowl screw today and there's no fuel in the bowl. I removed the fuel line from the pump body and fuel was flowing at a good clip. I replaced diagram A and B in the pump body a few years ago. Is it possible that the diaphragms can go bad and not allow fuel into the carb? I did a visual inspection on the diaphragms and they looked "OK" but I don't have anything to compare it to.
One last note, I replaced the NGK plug with the same plug early this year and have had no issues. The engine has run great until 2 weeks ago.
Looking foward to to everyone's thoughts.
