I have a tohatsu 2 stroke 8 HP. I am trying to replace the lower unit seals and water pump. I have the lower unit apart but cannot get the prop shaft out. Do I need a puller? I have the prop off. Do I try to remove the housing then the shaft? What holds it all in? I need to replace the seal.
You need to know and understand how the prop shaft and clutch and housing are assembled. Refer to your Factory service manual.
