Just got a 6hp nisssan four st
Just got a 6hp nisssan four stroke used 2001 about 60hrs. run time. only ran one time today for about 10min. My question is about water outlet stream and temp. of water. When running motor cooling water exiting motor is not what i'd call pissing a good stream its more like a good spray also water temp. is almost too hot to hold your hand under. i tried cleaning tube with wire and seems to flow better with wire poked in there but soon returns to good spray when removed. My question is this normal? Dont want to change impellar if i don't need to. Also I noticed there is a thermostat on this motor what temp does this open up at and how do you tell if its bad sorry for long winded question thanx Neil
