"No trouble for past year that
"No trouble for past year that I've owned this motor. Replaced plug, wire, inspected filter ... runs fine. Started acting up and refused to idle the other day, noticed pee stream was intermittent. Replaced impeller, it was missing 1-1/2 vanes ... I don't think I removed that much material from the water line ... blew out the line with compressed air blown into the telltale. Now the pee stream seems OK, but, engine won't idle or run, belches exhaust from below the water line and through the rubber access port cover for the shift linkage. Do I have a clog in the exhaust from a piece of the impeller and the back pressure is killing the motor? How is the exhaust configured on this motor.
Thank you motor gurus!
W--"
W--"
