Older Nissan NS5B that ran all last season and now it will run fine at low RPM and then with higher throttle it will just die and not restart with fuel in the venture. It will not restart and run unless I strip the carb down and put it back on dry. Run again fine and then at high RPM stall and never restart normally.
Things that have been done:
- Lower unit pulled and impeller done
- New head gasket
- Good compression
- New plug
- Replaced the carb, same issues! plenty of fuel.
I'm at a loss, it's like the float is set at the wrong level and then it just floods, but it won't come out of it.
- New head gasket
- Good compression
- New plug
