aviator727
Hi.
Thanks for looking at my post.
I own a 30hp nissan outboard 4 stroke engine. It has problems running properly. Here are the problems.
It starts ok with LOTS of choke. If I run it with low choke it usually dies. IF it doesn't die and IF i can get it in gear, then it runs at very low rpm and has no power. It purrs beautifully with high choke. Runs rough with low choke or dies.
The air intake is clean. New spark plugs didnt help. I got new fuel and ran a carb cleaner through it at high choke.
I have had the engine come out of the water in a turn at high power and the engine reved high. Is ESG (rpm limiting)a player?
The manual says that if it happens to see a dealer. What does it do to the engine?
Also, is there a high power and low power portion of the carb? Seems that OCCASIONALLY, I can get it to run great with lots of power, but then if i hit a wake or something....it defaults to running poorly and not wanting to idle again.
Thanks again for looking at this post and any help you may have to offer.
PVANV I wish you lived next to me at the lake!!!
