My 30a3 motor runs fine at idle and up to about 2000 rpm under load, and runs fine up to high RPM with 'just' the throttle, then as I slowing open the throttle in gear, it starts to miss slightly and stumbles more, the more I open it up, and won't wind up, misses badly, and has a loud low bogging sound. I have cleaned the carb in an Ulstrasonic cleaner, checked the fuel pump, filter and lines. At full throttle under way I have tried applying some choke and it doesn't help, nor does squeezing the bulb.
Are there ignition issue the would only present themselves under a heavy load?
Thanks for your help
Ron in Port Orchard, WA
