I've had this motor sitting about 5 years and am trying to bring it back to life. I replaced the spark plug and cleaned out the fuel bowl and was able to start it. The bowl was seriously caked up in white crap (im guessing that is ethanol residue) but it did start and would idle with the choke open after a while. I did not drain it before last use so I realize Im paying for that now.
I have removed the water pump and am waiting on replacement. It was pumping ok but 6 years is a long time.
The motor seemed unresposive to throttle increase with a prounouned delayed response. I have the carb apart and cleaned it up.I also have a rebuild kit on the way.
How important is it to remove the needle jet from the carb? It seems like its pressed in there and the rebuild kit doesnt have any replacement for it.
Also on the front of the carb near the choke there are two holes... one is open and the other seems to have a metal filling almost like there is a plug in there. Is that normal or do i have a major blockage?
Also, can I test run the motor without the prop on?
Thanks in advance
Thanks in advance
