Ive just bought a boat with a 2004 40 hp J50PLSRS outboard which has a gearbox oil leak and as yet I have no service manual for it. Firstly does the bearing housing come out of the casing easily as I suspect the o ring is the problem and secondly where do I disconnect the gear shift to enable me to remove the lower leg so I can check the upper seals and water pump, thanks Jeff
