Genehereiam
I am a little more intimate with my "new" motor.
I am starting to check the motor over from bottom to top & visa versa.
It's a 2006 9.8 4 Stroker.............Tiller control.
My questions, etc. this time.
Is there supposed to be a gasket / washer on the oil drain bolt ???
If so, is there any reason why I would need to go to a dealer when I can get a nylon or rubber gasket / washer at a local big box store ???
There is NO dealer within 40 miles of me for parts or question asking.
Same question for the lower unit oil plugs.
I am thinking a nylon washer of the appropriate size might do the trick ???
The fellow I bought my used engine from didn't tell me ALL of the truths.
Imagine this ??? !!!
First off, he "skidded" the motor, with the WRONG side down.
He told me he drained the oil out of it before he shipped it.
NOT !!!
My question here.
Is this going to cause me a problem with oil getting into the carburetor ???
I read (on line) where a guy had trouble transporting his motor with the wrong side down and oil in his carb caused him a few problems.
I DID drain the oil from the engine and the lower unit.
There was NO indication any thing is wrong either place.
The engine oil looked like it IS time to change.
There is NO discoloration or foaming in the lower unit oil.
I will drive to Knoxville tomorrow to get the fitting I need to hook my gas tank to the engine.
Hopefully this guy will be a good source for parts and info ???
Thanx to any and all who answer here.
Anything you offer up will be received with LOTS of THANK YOU.
/ Gene
NOT !!!
My question here.
/ Gene
