Newbie needs help please.
fordnutjm
Hello, I'm new to the forum and new to boating. I have a Bayliner Capri with a 50 hp outboard Mercury. It is not pumping water and I've tried clearing the drain. I understand how to pull off the bottom end and replace the impeller. That's what I thought I would do next. The problem is the only numbers I can find on the engine is a tag that says: serial number 6308653. I don't know the correct impeller to order based on this ? I would appreciate any help.
Thank you for the reply. Do I need to unhook a linkage? Or remove the tab that's above the prop ? (See pic) if so, how do I go about it?
Put motor in forward.-----Remove tab above prop ( hidden bolt ? ) -----No shift rod disconnect needs to be done.
Ok, I feel silly ! I found it recessed in a hole. Got it apart and there is nothing left of the impeller! Up against the impeller housing there was a rubber o ring and a round spring just laying on it. Going to order replacement parts. I hope they come with instructions!
