Hi all - i just purchased a 1986 Merc 35 horse more or less sight unseen and started taking a look at it tonight. When i dropped the lower unit after draining what little oil had in it i noticed the water pump tube came with it and then i heard a piece drop inside the upper half. as you will see in the picture i believe it is the grommet that holds the water pump tube in place when installing the lower half back on.
Anyone have any ideas on how to fix or have see this happen before? you can see in the pic where it appears the grommet should be and is no sitting by the exhaust tube.
any advice would be greatly appreciated!
Thanks! Matt
Thanks! Matt
