91bluewater
"Hi all, I have a 1991 19'
"Hi all, I have a 1991 19' bluewater with what i think is a AQ290? lol, first off, how do I now which model I have?
I originaly had starting problems and thanks to searching on this board and buying a manual i traced the problem back the the ignition. I have always had problems flushing my engine, it seemed to never suck in the water, but running it in water it never had a problem. Anyway yesterday i took the boat out (salt water) and i could not get the boat going very fast before hearing a bogging sound and the engine realy heating up. I checked the exhaust risers and hoses and they were warm. actually hot, (these are new) so I let the boat idle and it cooled back down.
I ran it for a while going very slow trying to figure out the problem but came up with nothing.
When i got it home i went to once again try and flush the engine,,,,, wont suck it in.
So I looked a bit closer to find the raw water union (http://www.marineengine.com/parts/part_details.php?pnum=SIE18-2778&returntopage= 80240788.htm)
to be rotted away and the main hose disconnected.. There was debris from the union inside the hose as well.
So i think this is my problem, what i wanted to know is if my boat does not have a strainer, and some of the rotted union got into the exhaust risers and where ever else.. How do I clean or flush this out before it does more damagae?
I also reconnected the hose to what was left of the union to see if it sucked water in and I found water to squirt out the other side where the raw water hose is inside the engine compartment. Is it plugged?
Thanks for any advice in advance."
