chrisdoc0608
Hello all. I just recently purchased my first boat. I have a VRO 110 on it and I am experiencing some issues. I will start by saying that the VRO pump has been disconnected and I run premix. I familiar with two stroke jet ski motors so I am hoping many of the same principals apply with this motor. The boat ran excellent the first two times out, I went through about 20gal of fuel.
Issue 1) The last two times out, from the dock the motor idles well revs right up and runs fine. I stop and fish for a bit and get ready to go to another spot and it immediately begins to run poorly. I am not reaching full rpms, the only thing that will get the motor up to almost ull rpms is depressing the key a few times to prime the motor. Pressing the fuel ball does not help a bit. I have pulled the carbs and filters no trash in the carbs and a small bit of gunk in one of the filters, I do not believe that it is nearly enough to cause the symptoms I am experiencing.
Issue 2) The motor has a knock sound at low rpms. I fear it may have something to do with the crank. What are trouble shooting steps to take before I pull the case apart and inspect the crank?
Issue 3) The left side of my motor gets hot the right remains relatively cool. The left side is not too hot to touch or sizzle water if splashed on it, but it is noticeably hotter.... is this something to look into?
Issue 4) When going from neutral to reverse from time to time it sounds as if it grinds the gear then suddenly it will catch, sometimes it takes longer than others... Going into forward is nothing like this. I have changed the lower unit oil and no metal particulates came out of the old... again, any advice would be appreciated
Thanks in advance for any help!
