BACKWOODS BREAM BUSTER
Hello everyone...im new to the forum and hoping i can find some help here...the search option did not yield any help so here it goes...1980s mercury 50hp 2 stroke thunderbolt ignition.replaced waterpump impeller and housing plus all seals and gaskets as a kit with impeller turned in correct direction with a little grease in housing and water pick up tube seated correctly.noticed old impeller chewed up in pieces after removal.took it out for testing at the dock right after replacement and fresh gas...started it up, but it took abt a minute of operation before any stream from tell tale but was good and strong once going and worked flawlessly at low idle and wot all in a total time of abt 20-30 mins.pulled her back home and was confident everything was fine for the next day of fishing...well me and the buddies docked again and of coarse i checked to see if she was still pissing just for insurance only to see blue smoke/exhaust coming out tell tale after a minute of operation again...shut it off immediatly and checked for clog in the piss tube...no clog..put her back in...same thing again...loaded up and hauled ass back home mad of coarse.ok...pulled lower unit off again to check waterpump assembly again and noticed this grayish water oil mixture along the drive shaft and around the pump housing.Removed he pump again and the top gasket under the housing was broken...replaced it...put it all back together same as above and was confident that was the problem...filled up a big tank i had with water and sat the merc inside...started up fine of coarse but only a dripple from tell tale plus the same blue smoke/exhaust...frustrated i pulled he lower unit again and thought ok maybe its clogged somewhere in the passages.rigged up the water hose to shoot up the water pick up tube into the motor bc i dont own an air compresser and after about a sec or so there was strong backpressure but still no stream of water out tell tale.so i used he hose again but this time straight into the tell tale piss hole and water went in easily and back out the other end but not out the water pick up tube seemed like out the exhaust tube or around it i also noticed water coming out around the spark plugs so water jacket seal may be busted but it did not do that with the hose up the other end...so of coarse i thought i unclogged whatever was there...put her back together and lowered the merc back in the water tank again with enough water to cover the cavitation plate...fired her up with a better stream but still not adequate enough and noticed the water was steaming as it was coming out also..so i shut it of and let it cooled abt an hr and started her up again...NO WATER AT ALL jus blue smoke/exhaust...said the hell with another lower unit tear down...i never did a compression test because the old merc fires right up so i figure it doesnt need it...id hate to take it to the shop and pay more to fix it than its worth especially if its only a simple problem that i cant seem to booger out...sorry for the long story but i figure much detail is needed...i think i can send pics if needed...PLZ sombody shine some light on the situation so i can get back to the backwoods and bust some more bream..THANKS
