Have a 2016 bf60 on a 16ft skiff with, as advertised but not confirmed, 50 hrs.
Problem I’ve generally identified is the engine sat with bad fuel for a while. Had water in the tank which I’ve drained and fixed and a few bad fuel lines and bulb.
Early issue was the motor would run great and then jump rpm in the mid range and never get to wot. She’d eventually die and not want to restart. Believe we’ve fixed that by cleaning out the low pressure pump, vst, high pressure filter and cutting down the oring in the high pressure filter that tends to be an issue. I’ve also had the injectors cleaned.
After all that, I put the boat in the water and it’s now running really rough at idle and low rpm’s but under load and in neutral. The rpms are surging. This is a new issue. After running for about 10 minutes to se if things settled out, i shut it down and went to turn it back on. This time the starter motor wouldn’t crank. That eventually sorted itself out and again it turned over immediately but back to the surging rpms.
Any thoughts as to the new issue/ continued issue here?
