Hi guys!!
I still have that good ole 1978 70 HP Merc Outboard.. with a problematic shifter..
The prob I'm having is that when using the shifter throttle in either forward or reverse you have to also have to manually use the warm up throttle lever at the same time (the 2 hand method ) to get enough gas to get the motor to perform. It still wants to hesitate and stall under load when not using both levers.
Its almost like they are not aligned or syncronized to work together..
Its a head scratcher .. I bought this boat set up a while back, and this has kind of been an issue since day one for me.
Now since this thing is definatly not new and has probably seen a few repairs in her time; I wouldnt know WHO has done WHAT to this ole motor over the years..
Anyone have any ideas? I'd def welcome some input..
I'm going to take the shifter apart and look for anything inside that could be broken or loose i suppose.. and go from there..
J
J
