new question
frank geezy
hello everyone! I'm wishing all good health and great boating! Anyway i bought my 1st boat on march 1st. It is a 1971 Caravelle with a 1971 Evinrude 60 horse outboard. The boat is in great shape considering it's age. I test drove it and it ran great, got up on top of the water with ease. It sat for a couple weeks until i completed the required safety course to legally be on the water and now it won't run for more than 5 seconds. It has new plugs, new fuel pump, and new fuel. I don't understand how in two weeks she went from running like a champ to only 5 seconds??? It sounds as if she wants to go, she starts strong and then just dies like she's not getting fuel. It's a brand new pump though and the fuel is going threw it. So does anyone have the remedy to this problem? She's a pretty boat and I'm dying to get her on the water! I live on the Delaware river in New Jersey and across from Philly and the skyline is pretty awesome so would love to see it on the water! Please help!
Open low speed mixture screws 1/8 turn at a time and test run.--------You have to install a new water pump impeller too.-----Also test overheat warning.-----If it only has a wee red light I suggest a warning horn be installed.
So you put in new plugs, eh? What did you put in? Those 1971 60hp motors were notorious for running like crap with the original surface gap plugs. We learned long ago that they need QL77JC4 plugs.
I bought my 1st rig on march 1st, a 1971 Caravelle with a 1971 Evinrude 60 hp. it ran great. It sat for a couple weeks and now it won't run for more than 5 seconds. It has new plugs, new fuel pump, and new fuel, and the fuel is going thru the pump.
The above quote obviously modified for clarity... the KISS method. :)
Always..... Remove all s/plugs..........
Check compression. What is the psi reading of all cylinders?
Check the spark which should jump a 1/4" gap on that model with a strong blue lightning like flame... a real SNAP! Does it?
If no spark tester, you can insert a #2 philips screwdriver into the s/plug boot, then hold the screwdriver shank that distance away from the powerhead.
Just sitting for a couple weeks would have no effect on the engine.
The running great mention... was that before or after the new parts was installed? Have you been messing with the slow speed adjustable needle valves... or is it possible that someone else may have been messing with the engine without your knowledge?
The nylon retainers at the front portion of the carburetors, the ones that keep the slow speed needle valves from turning on their own, should be RED in color (tighter grip than original). If white or yellow in color, replace them.
Remove drain screws from the float chambers temporarily to check fuel for water. Also note that if using 6gal portable tanks, always put in a gallon of fuel first, then the oil, then finishing filling the tank. The NOTE mention is because IF one puts the oil in first in a empty tank, that allows raw oil to enter the fuel supply line to find its way to the carburetor(s) and engine will not run on pure raw oil.... so yeah, you're checking those carburetors for raw oil also.
The following is important!
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Do not reply with generalities such as the compression is great... the spark is perfect, that sort of thing means nothing to us. Be precise.
Let us know what you find.
Perhaps it is overdue for some routine service.----Remove flywheel.-----Remove distributor cap and rotor.-----Clean and set breaker points to 0.010"-----Inspect anti-reversing spring.-----Clean distributor cap and rotor.-----Carefully install parts.-----Rotor is keyed to the crankshaft
I think Frank "ran for the hills". Probably being a 1st time boat owner, he is now curled up in a dark corner and wondering what just happened. You know about the frog in the hot water? Too much heat, too fast.....he jumps.
Naw Tim... We gave Frank a lot to think about all at one time. He'll be back! <-- My best Arnold impersonation.
Ha! Great, Joe! I wouldn't bet on Frank, but Arnold is one of my favorites. Frank probably already sold the boat.
Could be Tim.... Best two times of a guy's life: When he buys that hole in the water... When he sells that hole in the water... But so close together 3/1/19-3/29/19?? I'm going to hang around a few more days.
I will bet you a 12 pack of Hamms beer that old Frank is gone for good. My brother in Orlando said its getting hot weather there now. You could probably use a cold one. I think that Frank probably found some "stupid" problem and never checked back on his post.
That's why I prefer fishing inland lakes.........Frank, are you out there? I think your problem is still fuel related. If the problem happened suddenly, it could be a piece of dirt or rust in the fuel pump.the screens in there have limitations.
