Poco_Merc500-64
My 1st attempt at saving a boat engine. I found lots of info over the web that helped me get to this point. 1964, Merc 500SL, 4 cyl, electric start only, no stator, no alternator, no rectifier (hence no charging system). Engine on a 1976 Trihull.
Recently ordered and still waiting for my manual. Gear control was damaged, ignition switch and wires were pushed inside housing - now fixed (I think). Was able to get starter to turn/crank over, but, no spark (on any plugs). Am about to remove Magneto and check points inside. Will look for something obvious... shorted coil?
Am I missing a step before I disassemble the Magneto assembly? Voltage reading somewhere? Impedance/resistance values?
Also, there is a red wire that is loose and hot (12/14 gauge). No idea where it goes. Don't know if this is the original harness that came with the 64 engine.
Thanks for any advice...
