Hi All First time post.....
I have a NS5B that came with my sailboat. My mechanic took it about 2 years ago, replaced the spark plug and changed the fuel tank. However it has not run since. Finally today I decided to give it a whirl. At first the engine did not start, so I removed the Carb, cleaned it out. It was a bit dirty and I cleaned out the Main Nozzle & Jet. So the engine started and will run at a higher RPM. I dies when the throttle is at idle. The weird thing and this is my first problem is that the difference between the throttle at idle and running at what sounds to be about 75% throttle is a micro inch. I'm talking about at the carb not the twist throttle. So it appears that the throttle is either revving nearly full blast or nothing all within a mere nano inch. The throttle will travel the entire distance..... Lost and Confused.... Thanks for any help you can provide... Jon
