I installed two brand new oil coolers on Sat. I ran both engines at the slip just to make sure I didn't have oil spraying all over the place but I knew they weren't really "tested".
Took it for a short run tonight, less than two miles and both engines ran at least 10 degrees hotter (and climbing) as the RPM's climbed. My port engine was a little over 190 and in the low 170's last Friday. Starboard was at least a 10 degree difference.
I dropped the hook and started checking the dipsticks. Both oil and BOTH trans dipsticks look a little funny. The fluids sort of wick away from the edges almost like there's a little wax on them. At first I thought it was water but the color looks fine. It didn't look like this before. The color didn't change when I checked again back in the slip. I would have expected the oil to get a little coffee looking if there was an internal leak. And now that I think it through, it would have to be four internal leaks right? I probably went a total of 3-4 miles.
Some sort of residue from the manufacturing process? It seems highly unlikely that I would get two defective coolers giving the exact same results. It also seems unlikely that I could have done something wrong (x2) but grill me just in case. I checked the Crusader manual just to see if I missed something but I don't see the oil cooler listed anywhere? Was I supposed to flush them first?
Other observations:
1) The new coolers are slightly different. One of the hose connections is a 45 instead of being straight. I installed new 1.25" with wire and now it has a slight curve instead of being straight.
2) One of the oil cooler lines on each side is slightly kinked. I think because of the age of the hose it's not quite staying in shape and the position of the fitting dictates that. I could move the fitting but then it would be really close to the pulley (it's close already, so was the old one). It's maybe a 10% difference, I'm going to order new hose tomorrow regardless. "Kinked" might be too strong a word, it might have been like this for years.
What do you guys think? Maybe I have two different issues happening at once.
Bob
Other observations:
Bob
