New motor-No sound-need help
Robert86
I have a 5.7 350 mag mpi and it was frozen and starter was bad. Fixed all the issues and replaced the motor. This is in a 2008 23 sea ray select raw water setup.
Anyway I didn’t realize I still had the battery connected till almost done and now when I have it all back together nothing happens. Just a loud constant beep with a system error across the screen. All wires seem to be in the correct place. New starter doesn’t make a sound. Radio works but trim also doesn’t work. Any advice would be greatly appreciated. Thanks.
After having been fully charged, and after having been at rest for about 6 to 8 hours (no loads) ........ a good wet cell Marine battery should read a minimum of 12.4 volts.
A battery that reads only 11 volts is likely dead.
So I put a charger on the battery and got the volts back up above 12. all is still the same. Everything works except the Motor of course and also the TRIM.... Is there a specific fuse that would control that? Also I looked at all the fuses on both sides the motor and on top, above battery cut off, and under the wheel all look good.
