New light
yeah wht Rob said plus what ki
yeah wht Rob said plus what kind of boat and how many batteries. etc As much info as you can give will helps us give you a better responce
"The best way if you are not s
"The best way if you are not sure of all the details of what you want to do and what exactley you want from all of us then my suggestion would be to hire someone to do it.
Otherwise take some pictures of what ever it is you are trying to do that we have no idea of and give all of us as MUCH DEATIL as possible.
EXAMPLE: I have water in my bildge, where do you think it came from?
Try to answer that one.............."
If you use small LED lamps the
If you use small LED lamps they can be connected to the main dash lighting circuit to come on at dark. You can also install a small switch to turn them on/off; you can tie the ground wires into the same lighting ground circuit. I'll send some ebay lamps.
