I just replaced my original head gasket with a Sierra and per a couple reputable sources did not coat it with Gasket Sealer. I started it up last night and almost immediately saw water coming out of several of the center head bolt heads and one tiny drop between powerhead and cylinder head. I retorqued in sequence again up to the 20 ft lb and it sealed up all but a very very small amount of the water coming out of one of the head bolts. I checked spark plugs and they were not wet so I am fairly confident water is not getting in there.
The head was not overheated before and appeared flat and I sanded it down with 220 on a flat surface and had everything very clean. I am betting if I would have used Gasket Sealer like the book calls for I wouldn’t have this problem but a couple experienced professionals recommended not using any sealer due to that it could affect proper torque specs.
With this very very small leak should I slightly torque more or start over with a new head gasket, run a couple more heat/cool cycles? Or, should the Sierra head gasket seal itself up? It was kind of shiny black, so will that seal itself through a couple heat/cool cycles? I have heard of the heat activated head gaskets. If I do start over I will sand down the cylinder head even more but should I use Gasket Sealer? The motor is a 3 cylinder 2000 60 HP and the OMC book calls for Gasket Sealer so why not use it like the factory calls for it?
Also, the gasket can go in both ways but I replicated how the factory one was installed because the rings were more flush on one side and rolled slightly different compared to the other. Should the factory lettering and stamping be faced a certain way?
Thanks in advance.
Thanks in advance.
