"200HP Johnson, 1987. Lower un
"200HP Johnson, 1987. Lower unit broke shaft Labor Day (other post regarding shift rod length)
Got another one, used the old pump (new last fall) and installed unit.
Tried to start it...just tries to catch on one, maybe 2 cyls. Does not start. Probably not plugs, but put 6 new ones in anyway.....no go still.
Inductive timing light shows I have fire going down the plug wire to the plug. Main fuse is not blown. (The hits on 1 or 2 plugs told me that I guess.)
Bulb pumps up good. Small filter under cowl is full of fuel when I unscrew it.
Disconnected the linkage to insure the shift rod is not throwing off the rev/fwd/start position. Moved throttle lever manually, still no go.
Any other thoughts to steer me in a direction. I have the batt charging tonight to test again in AM.
Thanks for any and all help, Greg"
