Doogietroudt
Allright here we go.. Got a boat for 300 sat for 3 years was winterized Going for full restoration. Some one did put a new floor in.. I pulled it out to check all the wood braces were clean like new looking wood with exelent resin.. so put bedliner on bottom side of floor.. same after re install.. Started boat new gas new oil ect. ( I have worked on cars and paint cars for years good at cars anyways) Started right up put ears on and no water impeller good.. so bypassed and hooked up hose on input side off the water pump. light water pressure.. ran good good temps felt good about boat.. So I fixed all the stress cracks I live in Colorado so boat was in great shape for that exept some rock scrapes on bottom and where some one hit the rub rail on a marine dock. So fresh paint was white and green now white and purple boat flake. Old school glitter for me!!! Then orderd seats today ready for interior.. Now i checked the oil and water in it.. drained all the oil left the oil plug in pan did a test with water from hose ( light pressure) conected to water pump.. water came out of flap clean as before. Hand turned crank over a few times Aprox 10 gallons of water ran throug.. Pulled out Oil plug and 4oz of water came out.. Pulled all the plugs checkd for water none.. So I pulled of water pump I noticed water behind the pump into the cam cover cavity... So I bypassed water pump and used the input hose after the water pump with the garden hose hooked up and did the same test again no water in oil pan...So I am wondering is it possible that I got lucky and its A bad water pump or a seal?? Im new to forums all together let alone boats. Grew up on boats know a little but this is my first boat.. Please help Thanks Alan Troudt I am sure I will have many more to come
