Jfreeman1412
Hey Guys I just purchased a 1973 Trojan F-30 with the Twin 318's. Here's a little background behind it, the guy I bought it from hadn't had it in the water for a couple years, he thought the fuels was empty but when we went to fill it up it was half(half of 90 gallons) full still. Took the boat on a test run and seemed to run fine for 15 minutes, then we took it also ran fine for 15-20 minutes and then the motors started starving for gas, to the point of vapor lock. We went back and change the fuel filters that are in line before the carb and put new plugs in. Didn't realize that there are other filters before the fuel pump until we got out the second time. When the engines started starving again we pulled the plugs on the bowl style fuel filters and the engines would run fine again for a while. We then had to put the boat in the slip and leave it because we were out of time and had to make it home.
We live in Minnesota and went to to the east side of lake michigan with the intentions of driving this boat across the lake to the wisconson side. So the boat is still on the michigan side and we are heading back out there at the end of this week to turn some more wrenches. I guess i was just looking for some advice and things to look for when we are trying to trouble shoot this engine. I have learned a ton from reading other posts on this site and appreciate any help you can give.
I'm sure the canister filters need to be cleaned or replaced, when we would take the plug out of the bottom a tiny bit of fuel would come out and sometimes that was with the engine running. Also could it be the intake in the tank? Although does have a newer tank in it(5-6 years). This would happen to both engines but at different times. It has one tank and is tee offed with canister filters on either side of the tee before the fuel pump. So I know I need to change the canister filters for sure, but was looking for any other advice so I can be prepared as possible. One engine has 1300hr and one has 940hrs.
