Hey, I went to rebuild the carbs on my 97 Evinrude 130 2 stroke as the boat sat for a while. I noticed in the rebuild kits it came with a gasket for the needle seat, more so realized after as none of my carbs had a gasket under the seat. Engine runs good, does shake some at that middle range right about 2200 RPM or so. If I put the gaskets under the seats it'll change the needle seat height, will the engine need to be re-tuned mixture wise? With the gaskets in there and the float down it slows the inflow of fuel a lot more than without the gasket. Should I take the carbs back apart and put them in though? Im about to take the boat with me to the keys for a week so adding the gaskets I wont be able to water test it until I am down there. Thanks.
