" Greetings from overcast Cent
" Greetings from overcast Central Illinois!
Joe and Zeke, I'm sure you guys can nail this one pretty quick, and I greatly appreciate any helpful advice the folks on this board can provide.
I have the chance to buy an old 16' wooden boat that has a 35 HP Johnson Javelin engine. The Model# is RJE 19M and the Serial # is 650612. As best I can tell this outfit dates to the early to mid 60's. The wood is in fine condition, it only needs a little sanding, elbow grease, and some polyeurathane sealant.
The motor hasn't run in over 5 years so I automatically assume this will need a carb rebuild and a new water pump kit. It is an electric start with cable & pulley steering system. The coating on the steering cables looks cracked so I imagine that will also need replaced.
I've replaced the water pump on my 1978 Johnson 70 before but I have no idea on this old 35HP (and I would bet it's quite different). Can you point me to a guide for this or tell me where to look? Also, can you provide me info like fuel
il ratio, compression, and various other tests/info before I try to fire the engine?
Again thanks for the help. I'm that as I dive into this (if the wife let's me) I'll more questions.
Kevin "
Kevin "
