Need year and HP information
Hi looks like i have same problem as you did you ever get to know which gearcase,s are interchangable with a 1976 55hp 55673e could do with finding out myself thank,s
2 cylinder units from 76 to about 1988 will fit -------40 HP / 50 HP / 55 HP / 60 HP, non commercial only----------Commercial motors of this type use the 3 cylinder lower unit because these 2 cylinder units are not very robust.
Hi found a possible doner gearbox all looks the same except for a small square hole at top part of leg directly above prop what is this help please
I believe that hole is for a " sacrificial anode "----very easy to confirm that using the parts pages.---------I believe that post #3 is very clear !
