Whttnbrg, you will find people that do not understand how to determine Engine Rotation... so just that we're both on the same page here:
The Standard LH rotation engine will turn CCW when viewed from the flywheel end.....
same as all car and truck engines.
Conversely, the Reverse RH rotation engine will turn CW when viewed from the flywheel end.
Here is how your Rev RH engine will rotate, as shown turning Clockwise.
This is just oposite from Car/Truck rotation and is the industry standard means of determining engine rotation.
I have a 1987 reverse 454, i also have a zf 63a I need to reverse the motor to use the gear. I have been told three different things and I don't know what to believe.
1. With the motor being a 1987, all I need to do is change the timing from the gear set to the chain.
2. I need to change the timing, cam, and lifters.
3. I need to change the crank and everything above.
Is there anyone that can tell me what I need to do. My brother is a mechanic, and will help me do the
work, I just want to make sure I do it right.
You are receiving some incorrect advice!
1. No... that is incorrect!
The Rev RH rotation camshaft cannot be re-used for the Standard LH rotation engine because the Intake valve
initial operation occurs first, with the Exhaust valve
ending operation occuring last (within the four cycles).
Cam indexing, over-lap, duration, etc, etc, just won't allow for this.
Also..... camshaft indexing and profiles vary depending on which drive system....
I.E., sprockets and chain drive -vs- twin gear drive -vs- 4 gear drives, etc, for examples.
2. Yes on the camshaft and new cam follows. New cam follows are necessary for a new camshaft unless roller cam/followers.
3. Incorrect regarding the crankshaft. Crankshaft is the same..... we're simply rotating it oposite.
The wrist pin offset will require being changed.
Chris, correct me if I'm wrong here..... but he won't want to flip the connecting rods around since they will be numbered and must face the correct direction within the crank journal. The wrist pin offset is addressed by changing the piston orientation on the connecting rod.
Whttnbrg, imagine this being a Port side cylinder head that has been tilted up to expose #1, #3, #5 and #7 cylinders.
The valves are arranged from #1 to #7 cylinder;
Exhaust/Intake, Exhaust/Intake, Exhaust/Intake, Exhaust/Intake.
The valve reliefs in the #1, #3, #5 and #7 pistons reflect and follow the valve configuration.
A good machine shop person can change the piston/rod orientation........ but I doubt that you'd tear into this without replacing pistons.
Crankshaft main seals differ from Standard LH rotation to Reverse RH rotation by a change to the tiny serrations at the seal lip.
These wipe the oil differently from LH to RH rotation.
Distributor and oil pump will always rotate standard (CW when viewed from overhead).
The cam and distributor "drive" and "driven" gear cuts maintain this rotation.
IOW, there is no REV oil pump.
However, there will be a difference in the up/down thrust load within the distributor.
Ignition timing and indexing is oposite from Standard LH ignition indexing, begining with #1 cylinder.
The Std. LH rotation firing order is 1-8-4-3-6-5-7-2 ..... the Rev RH engine firing order will be 1-2-7-5-6-3-4-8.
Question: typically a Rev RH engine is worth a bit more than a standard LH rotation engine. Why not sell the running Reverse RH rotation engine, and build or buy yourself a Standard LH engine?
