"Hi everyone,
I was having
"Hi everyone,
I was having trouble with my Honda BF8A in that it wasn't idling properly and stalled during idle. The engine is a 2008 and has 15 hours on it.
My wife hit a rock with it just before it started acting strange.
I read a post on here saying that someone had their timing belt slip from an impact with a rock, so I was attempting to move mine one notch in either direction to see if that was a problem.
Well, I MESSED UP!
I lost the timing entirely.
I see the dot on the wheel that controls the valves. I see the notched dot in the engine casing. I assume you line both of these up.
However... I can't seem to figure out how to line up flywheel! I see the IF and IT markings on the flywheel, but see nothing to line those marking up with. They are about 1/2" to 3/4" apart from each other.
Questions:
1) What do I line those IF and IT markings up with, and which marking do I use?
2) Am I right to guess I line the small drilled notch in the cam/valve wheel up with the similar sized notch in the engine block?
3) There is a white line on the belt. I have no idea what to use this for. Anyone?
Speedy replies would be appreciated because I have to pick my wife up in 3 hours at the dock, I live aboard, and this is my only means of transportation. I can't row in. The current is too strong."
I was having
"Hi everyone,
Well, I MESSED UP!
Questions:
