96pursuit6.2
Okay so I bought a 2000 mercury 25 outboard that hadn't been used for awhile. It was in great cosmetic shape and starts and runs fine until almost wide open throttle. At that point it will shut down and I can't pull the rope. It's seized somewhere at that point. After sitting for awhile it starts and idles fine. There is no scouring in the cylinders and the compression is at 120 on both cylinders so I'm led to believe the issue is not there. It has done this repeatedly. The thing is cooling great as well. Steady stream and max cylinder temp is 138. I'm lost here. The thing runs super strong until wide open. Also, when it does stop there is a light clicking sound until I return the tiller to neutral. I have had it at the shop with no luck other than a possible crank bearing seizing when it gets hot? They were baffled. I'm hoping somebody has seen this before and can provide any insight. The serial number is OTO43459.
