I don't have the diagram but drawing from memory, it's just a case of matching a outgoing valve fuel flow to a related cylinder on the same bank as follows. If I'm wrong, I'm sure a fellow member will jump in here with the proper info.
...Valve Feeds Cylinder
....Port...........Starboard
2 feeds 4........1 feeds 3
4 feeds 6........3 feeds 5
6 feeds 2........5 feeds 1
Are you sure they're recirculating hoses... OR... are they hoses leading from a fuel primer solenoid to the intake manifold, needed to prime and start the engine?
The fuel primer solenoid would have need of a spliter as only two hoses lead from the solenoid and you need 6 (pictured) to lead to the intake manifold (or carburetors). This would coincide with your penciled diagram.
