need raw water pump brackets
scavengerdog
I'm working on a 1965 roamer 33 with 327f engines. the starboard engine has had a "field repair" of the raw water pump brackets. the result is the upper bracket is missing (replaced by an auto alternator bracket) and the lower one has failed under the strain. While i can probably make something that will function, this is a weekend thing (got a regular job, dammit) and that project would likely mean the end of the season for this boat owner. if there were another mechanic locally who could fix it sooner i would gladly give up the job to someone else... has anyone got these in good shape for sale? does anyone know where i can find them?
Is there adequate space in front of the harmonic balancer (minus the belt driven sea water pump pulley arrangement) for a Johnson F5B-9 sea water pump?
Here's the larger F6B-9 version.
The inlet/outlet ports would face either Port or Stbd.
This would allow you to rid yourself of not only the belt driven sea water pump bracket, but also of the belt driven sea water pump blues and issues.
The F5B-9 and F6B-9 are RH or LH rotation capable.
