"Boat is a 1991 18ft Marada wi
"Boat is a 1991 18ft Marada with 1990 (pre balance shaft) 4.3 Cobra. I have added Vortec heads and Edelbrock Performer manifold, 1409 carb, and K&N arrestor. I'm estimating HP around 215-225. Current prop is a 14.3 X 21" Solas "Amita" 3 blade aluminum. WOT RPM is right on at 4500-4600 @ 50MPH w/GPS. Hole shot is not great. I have the same prop in a 19". Engine obviously over revs with it. I've seen 5000 and had throttle left over.
I am looking to improve hole shot and not give up too much speed. I'm torn between a vented SS 3 blade or a SS 4 blade such as the Solas HR Titan 4. I've read Hystat's comments on the Raker and I'm wondering if it would be a good fit for what I'm trying to do. If so what pitch would be recommended? I've seen a couple of 20" Raker for sale. If I decided on a 4 blade what pitch would you guys recommend?
I've attached a couple of before and after pics of my boat that should give an idea of hull design. BTW dry weight is around 2640 lbs.
Any input would be appreciated.
boat1"">
boat2
