I have a 1979 mercury v150, I just ordered a poppet valve kit for it and the rubber diaghram is too thick to fit in my housing, also it came with a metal disk that goes behind it but mine didn't have one and it wouldn't fit correctly when trying to put it on, all gaskets worked fine. I also have a hole in the poppet cover that had a screw in it but not sure if that is suppose to be like that or if the previous owner did it to keep the valve closed. I'm lost and not sure if there is a different kit to buy or if I should buy a whole other assembly and even then I'm not sure which one to get or where to get it, this thing is hard to find and it really does not help that I can't find a serial number on my motor. It's not on the block behind the flywheel, the part number is 65663 but I obviously got the wrong kit ordering it that way, any suggestions or help would be appreciated.
