A
AC
Guest
Hello-I need help guys. I am a
Hello-I need help guys. I am a newbie-I'll try to be detailed. I have a 1998 stingray with a 3.0 merc 4cyl. alpha 1 drive. I have it on a slip. When I go to the boat-it looks like the exxon valdez around the motor from a oil leak. As best as I can tell-it is coming from the fill on the front of the motor for the upper gear housing. I have to fill it upon arrival everytime. It only seems to go as low as to the add fluid line but it does not look good floating on the water behind the boat. I did pull it out of the water and the oil appears to be coming from the right side water exit hole. I am mechanically inclined and with a good manual-I would not hesitate to jump into this-but can someone give me a good point to start or advise as to what I should look for here. I am assumming the oil is going out of the upper drive into the cooling system somewhere and I have a small idea what this deal looks like inside but if someone has a diagram of the cooling system real quick-I would love to see it-thanks a million ahead of time.
