1992 johnson 140 looper (v4). Got out there to do some maintenance today, and decided to run the engine a bit on the muffs since it's been a couple of weeks and I didn't fog it yet this winter. In my haste, I completely forgot to turn on the ON lever at the muffs and ended up running it for about 1-2 minutes without any water going through it. Once I realized my blunder, I turned them on and had a good tell-tale stream so I figured all was well. A few minutes later I start seeing milky oil sludging out from the little vents just above the AV plate.
I was actually about to change the oil, slap on a new prop (with some new grease on the shaft), and change the impeller, casing, and gasket anyways later on this month, but now I'm guessing I've blown at least one seal. Any ideas on which seals I should go ahead and purchase before taking it all apart, and is it all easily accessable? Never done an impeller change out before and wasn't planning on doing seals too... No idea as to the difficulty level for a backyard enthusiast. Links to any vids would be AWESOME... Also other than draining what may be left of the current oil, what kind of cleanup will be necessary if the oil and water mixed? Thx all!
